James Taylor
Hi Mike,
Thanks for getting back to me. I have included this command - it works for the first attempt but will not work in a for-loop for subsequent steps. It updates the timestep but not the load values.
I've tried to use this command with the cable force modules also. It doesn't appear to work when these modules have question marks beside them, which happens each time the hydro pressure time step is updated.
I've attached an image of my code, I hope it makes sense.Code sample showing the steps used to automatically update timesteps for imported Aqwa modules in Mechanical
