Ansys Learning Forum Forums Discuss Simulation LS Dyna LS-OPT Error Reply To: LS-OPT Error
igandiko
Did LS-OPT try running ls-dyna jobs? Please see if it created a directory for the ls-dyna stage and then job directories (1.1, 1.2, etc) inside this stage directory. If it did, please check job_log file in 1.1 for the error. My guess is that you did not specify correct ls-dyna solver command in stage solver settings. Please select your local ls-dyna solver exe in the solver command field.
