Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to plot the E-field distribution of an Infinite antenna array › Reply To: How to plot the E-field distribution of an Infinite antenna array
Nooshin Valizade Shahmirzadi
Thank you for your reply. My antenna array is in direct contact with compressed breast tissue, so I defined different layers above my antenna unit cell (absorber-10mm, skin-2mm, heterogenous medium (category D)-52 mm, skin-2mm) which emulate my phantom properties. I defined a 200 mm by 200 mm non-model plane in the middle of the first skin layer. You can see it below:
You can also appreciate how I defined boundaries and excitation in my unit cell from the top screenshot.
You can see the antenna itself in the following figures and the floquet port which is defined on radiating surface.
The E-filed distribution is also provided.
I wanted to attach my HFSS file to this discussion, but it’s not allowed.
Kind regards,
Nooshin
