Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Exporting Stiffness matrix and Mass matrix from Ansys WB › Reply To: Exporting Stiffness matrix and Mass matrix from Ansys WB
dlooman
Can you use Harwell-Boeing format?  You can export the stiffness and damping matrices in that format with the HBMAT command.  I don't know a way of computing stiffness and mass matrices for just the beam elements unless the the solid elements are suppressed.
