Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Enquiry on graphics error with Ansys Aqwa › Reply To: Enquiry on graphics error with Ansys Aqwa
Ingrid M
if you look at the line right below "COMPLETE SUCCESSFULLY", you will see a message that indicates that one of the cables you have defined is too short. You might want to increase its length and the distance between its attachement points.
I hope this helps.
Ingrid
