Ansys Learning Forum Forums Discuss Simulation Photonics Charge solver electrical contacts Reply To: Charge solver electrical contacts
nuaman.m.kutty
Hi Amrita,
Thankyou for your reply!
I was double checking this simualtion that the results are true not not. The porject that I posted happened when I tried it for the second time, which means I already had results of the same LED stack with different compinations! However, it worked again when I started a new project from scratch! But the results (I-V curve) is slightly boosted with similar trend.
I have several confusions regarding the solver. How are these domains created? sometimes the domains are created as a single one if there are same material for geometries adjacent to each other, but now I noticed that the solver defined the domains as different ones for the same condition. Secondly, when the solver is not able to converege the results after many iterations, If i just go throgh all the objects/ domains/ BC, and then runs it, sometimes it runs, or if i just close the project and reopen it again then >layout>partition>run, it runs!
So I doubt that I need to understand how things work properly or the solver is not running properly!
Will it be possible to have a zoom meet or any live sesseion to clarify more about the CHARGE solver? It would be great if you could makei t!
Nuaman
