Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys CFX Youtube Tutorial error › Reply To: Ansys CFX Youtube Tutorial error
V.P
Hi Ray,
I tried the tutorial and it is working without any errors. Can you go through the steps again and check? Also, dont try to increase the Global size factor beyond 1.2 as mentioned in the video, because the mesh size might increase and that Ansys Student version has 1 Million cells/nodes limit.
Also since the case stops at the solver manager, can you look at the Out file carefully. In the last sections of the Out file, you will see error or warnings which might give a more clear picture of the problem.
