Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Composite overwrapped pressure vessel.Dome with varible angle & thickness › Reply To: Composite overwrapped pressure vessel.Dome with varible angle & thickness
March 13, 2024 at 9:26 am
Please see if the following link helps you: How can I setup variable winding (fiber) angles on a COPV (composite overwrap pressure vessel using ACP and tables capabiliity? The fiber angle changes in the dome region and I need to account for the changing angle. - Ansys Knowledge
Ashish Khemka
