Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need help with sheet metal behavior › Reply To: Need help with sheet metal behavior
Vincent Doan
I was advised to use 2D plane strain in Static Structural. But this issue happened to me:
when it reach the final destination, the sheet metal disappeared. And I also get this message: "Solver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully."
How can I resolve this issue? Thank you
