Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Updating Model in Workbench Taking Too Long › Reply To: Updating Model in Workbench Taking Too Long
March 13, 2024 at 9:06 am
The geometry appears to be complex, which may cause a slightly longer update time in the mechanical design. Do you also encounter long update issues with simpler geometry?
Here are some suggestions to try:
Copy the geometry and paste it into a new design tab in the SC software. Save it locally on your system. Then, attempt to import it into the Mechanical environment.
Utilize the "Reduce and Regularize and shrinkwrap" tool located under the "Facets" tab. This can help reduce the number of facets in the body, potentially improving update times.
Best Regards,
Sampat
