Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Exporting Stiffness matrix and Mass matrix from Ansys WB › Reply To: Exporting Stiffness matrix and Mass matrix from Ansys WB
March 13, 2024 at 12:18 am
Thank you for your reply, Dave.
I will make sure to look into those options as well.
For this specific project, I need to have the full matrices (Stiffness & Mass) in order to feed it to an established Matlab code.
Update:
I tried to supress all the solid elements, and the code is generating the output just for the beam elements.
Is there any way i can get the same output without supressing anything?
Thank you for your help!
