Ansys Learning Forum Forums Discuss Simulation General Mechanical User-defined hyperelastic material model for workbench structural simulation Reply To: User-defined hyperelastic material model for workbench structural simulation
yu272
Hi Sahil,
Thank you for the information! To be more specific on my question, I will need this material model to do FSI simulation, and the solid will need both proper tension and compression. Therefore, it would be good if we could use some APDL command to control if the strain is negative, it can use a different model. Is this possible?
Sincerely,
Eric
