Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical help, dielectric slab waveguide Reply To: Lumerical help, dielectric slab waveguide
Amrita Pati
Hi Marton,
You can do far-field projection from FDE, using both GUI and script. After you calculate the modes, you can click on the drop-down menu from the "options" to set the far-field parameters and calculate the far-field projection.
I didn't fully get the interference part. What is the interference supposed to be between?
Amrita
