Ansys Learning Forum Forums Discuss Simulation Electronics Export a material from Maxwell to Fluent Reply To: Export a material from Maxwell to Fluent
Ivonne Marti
Hello Krisztián,
Maxwell materials look at the electromagnetic characteristics and the materials in Fluent to the fluid-dynamic ones. This is the reason why the materials are not shared between both tools and why the input characteristics are different.
Since each tool has his own material library, you can try to choose same materials and re-write the common characteristics to be the same.
I hope this helps. Ivonne
