Ansys Learning Forum Forums Discuss Simulation Fluids UDF compile error Reply To: UDF compile error
alinalarin
Thank you Rob!
I tried. That is what I receive:
> Copied C:\udf/SLIP2.C to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_host\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\scons_test.bat "libudf\win64\3ddp_host\scons_test.bat" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_host")
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\udf\libudf\win64\3ddp_host\SConstruct", line 8, in
File "C:\udf\libudf\win64\3ddp_host\SConstruct", line 18, in
Compiler used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\clang-cl
Linker used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\lld-link
File "C:\udf\libudf\win64\3ddp_host\SConstruct", line 152, in
Copy("C:\udf\libudf\win64\3ddp_host\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v222\fluent\ntbin\win64\resolve.exe")
c_sources ['SLIP2.C', 'udf_names.c']
c_sources_ []
In file included from udf_names.c:3:
C:\PROGRA~1\ANSYSI~1\v222\fluent\fluent22.2.0\src\udf\udf.h(80,12): fatal error: 'ud_io1.h' file not found
# include "ud_io1.h"
1 error generated.
scons: *** [udf_names.obj] Error 1
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\scons_test.bat "libudf\win64\3ddp_node\scons_test.bat" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_node")
File "C:\udf\libudf\win64\3ddp_node\SConstruct", line 8, in
File "C:\udf\libudf\win64\3ddp_node\SConstruct", line 18, in
File "C:\udf\libudf\win64\3ddp_node\SConstruct", line 152, in
Copy("C:\udf\libudf\win64\3ddp_node\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v222\fluent\ntbin\win64\resolve.exe")
c_sources_ []
1 error generated.
Done.
