Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF compile error › Reply To: UDF compile error
alinalarin
I tried built in compiller and recieved following error:
Copied C:\Cell100_files\dp0\FFF-6\Fluent/C:\Cell100_files\dp0\FFF-6\Fluent\SLIP2.C to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_host\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\scons_test.bat "libudf\win64\3ddp_host\scons_test.bat" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_host")
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_host\SConstruct", line 8, in
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_host\SConstruct", line 18, in
Compiler used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\clang-cl
Linker used is "C:\PROGRA~1\ANSYSI~1\v222\fluent"\ntbin\clang\bin\lld-link
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_host\SConstruct", line 152, in
Copy("C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_host\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v222\fluent\ntbin\win64\resolve.exe")
c_sources ['SLIP2.C', 'udf_names.c']
c_sources_ []
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ")
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v222\fluent"\fluent22.2.0\src\udf\scons_test.bat "libudf\win64\3ddp_node\scons_test.bat" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_node")
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_node\SConstruct", line 8, in
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_node\SConstruct", line 18, in
File "C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_node\SConstruct", line 152, in
Copy("C:\Cell100_files\dp0\FFF-6\Fluent\libudf\win64\3ddp_node\resolve.exe", "C:\PROGRA~1\ANSYSI~1\v222\fluent\ntbin\win64\resolve.exe")
c_sources_ []
Done.
