Ansys Learning Forum Forums Discuss Simulation Preprocessing New Geometry causing CFX mesher to crash Reply To: New Geometry causing CFX mesher to crash
V.P
Hi Jett,
Since you replaced the original geometry with a new one, assigning a new mesh cell to it would be the solution to this.
When you changed the geometry the original mesh parameters aren't scoped properly to this new geometry which is causing the error. If it was a slight modification to the original geometry this wouldn't have happened, but since you completely replaced it with a new one, scoping errors can be usual.
