Ansys Learning Forum Forums Discuss Simulation General Mechanical Axisymmetric model of Composite overwrapped pressure vessel(COPV) Reply To: Axisymmetric model of Composite overwrapped pressure vessel(COPV)
harshanagasai668
Dear Sir,
Firstly thank you very much for stepping forward as a helping hand. Comparing the results of an Axisymmetric model, a shell model and a 3D solid model is a part of my project, which is why i am determined to model an accurate Axisymmetric model of a COPV. It will help for my analysis if i could model an axisymmetric model. Coming to the 3D solid model, I modelled it with the help of a Lookup table and cut off section rule. I am sure that there might be a mistake in my 3D modelling process as the failure index exceeded the treshold value by a lot and i am in my way to correct the path i took up on.Â
