Ansys Learning Forum Forums Discuss Simulation 3D Design Problems with finding the connections folder Reply To: Problems with finding the connections folder
Sampat Kumar
Hi
Right-click on the model(F4) and see if the connection option is highlighted or not. As I can see from the image it's a single geometry in your analysis that's why it's not highlighting connection folder. You can create two geometry then it will update the connection folder in the mechanical.
Best Regards,
Sampat
