Ansys Learning Forum Forums Discuss Simulation LS Dyna Using CONTROL_REFERENCE_CONFIGURATION Reply To: Using CONTROL_REFERENCE_CONFIGURATION
bl1019
Dear Reno,
Thank you for your suggestion.
Unfortunately, I cannot bypass the 'case' option manually - as explained by our manual, the keyword CONTROL_REFERENCE_CONFIGURATION_ITER was built upon case, hence, users do not manually pipeline the iterations, but let the software do its own job.
I will try with the Linux version, although it may take some time to configure the environment on an old workstation.
By any chance, would it be possible for you to kindly pass this issue to the development engineer to take a quick look? I am happy to provide you with the script in whatever way that complies with the regulation.
Thank you,
B
