Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Deflections not matching for simple cantilever beam check › Reply To: Deflections not matching for simple cantilever beam check
March 11, 2024 at 9:24 pm
Back to your question, I don't know how to make the integration rule, characterized by 3 through-thickness integration points of equal weight, any more accurate. If you only have 3 plies in a composite, it's recommended you use at least 2 integration points per ply.
