Ansys Learning Forum › Forums › Discuss Simulation › Photonics › RCWA results are quite different from FDTD › Reply To: RCWA results are quite different from FDTD
Hi Amrita,
Thank you for the comments.
I tried the tangent vector field with 3000 k vector (it ran almost 24 hours). The results improved but still displayed significant differences when compared to the FDTD simulation results
Below is the comparison:
I also compare the results with or without checking tangent field vector for 1000 k vectors.
Here is the field distribution (xy cut) at the center of my structure for the wavelength at the peak. Gold structure is at the center.
RCWA:
FDTD:
Here is my RCWA solver settings:
Do you have any furthure suggestions? I am still runing simulation with 4000 k vectors. However, it might take a very long time.
Guodong
