Ansys Learning Forum Forums Discuss Simulation General Mechanical MAPDL convection load with variable film coefficient and bulk temperature Reply To: MAPDL convection load with variable film coefficient and bulk temperature
Francesco Miccoli
Thank you for the help with commands, it happears as if the film coefficient and bulk temperatures are not interpolated (note that I have used the APDL commands I sent in the reply before, but started the X vector from 0.13 instead of 0):
***** MAPDL RESULTS INTERPRETATION (POST1) *****
 *** NOTE ***                            CP =      26.344   TIME= 21:23:59
 Reading results into the database (SET command) will update the current
 displacement and force boundary conditions in the database with the
 values from the results file for that load set.  Note that any
 subsequent solutions will use these values unless action is taken to
 either SAVE the current values or not overwrite them (/EXIT,NOSAVE).
 USE LAST SUBSTEP ON RESULT FILE  FOR LOAD CASE 0
 SET COMMAND GOT LOAD STEP=     6  SUBSTEP=    51  CUMULATIVE ITERATION=   449
   TIME/FREQUENCY=  6.0000
 TITLE= mk1--Transient Thermal (L5)
 SELECT      COMPONENT NOZZLE_SELECTION
 LIST ALL SELECTED NODES.   DSYS=      0
 *** MAPDL - ENGINEERING ANALYSIS SYSTEM  RELEASE 2023 R2          23.2     ***
 Ansys Mechanical Enterprise Academic Research
 01148981  VERSION=WINDOWS x64   21:23:59  MAR 11, 2024 CP=     26.594
    NODE        X             Y             Z           THXY     THYZ     THZX
        1  0.18635       0.27697E-001   0.0000          0.00     0.00     0.00
        2  0.13040       0.28297E-001   0.0000          0.00     0.00     0.00
        3  0.18540       0.27418E-001 -0.60031E-017     0.00     0.00     0.00
        4  0.18444       0.27129E-001 -0.57611E-017     0.00     0.00     0.00
        .... (omitted)
       50  0.14257       0.16494E-001  0.45903E-017     0.00     0.00     0.00
 01148981  VERSION=WINDOWS x64   21:23:59  MAR 11, 2024 CP=     27.531
       51  0.14178       0.17095E-001  0.46890E-017     0.00     0.00     0.00
       .... (omitted)
     1735  0.15704       0.14044E-001  0.17629E-017     0.00     0.00     0.00
 01148981  VERSION=WINDOWS x64   21:23:59  MAR 11, 2024 CP=     28.703
     1737  0.15620       0.13509E-001  0.20108E-017     0.00     0.00     0.00
     .... (omitted)
     1797  0.13145       0.27243E-001  0.56777E-017     0.00     0.00     0.00
 *** NOTE ***                            CP =      29.406   TIME= 21:23:59
 The surface loads listed are the current database values and are not
 necessarily the values corresponding to the current results data set.
 Tabular boundary conditions, however, do list values corresponding to
 the current results set.
 LIST NODAL SURFACE LOAD CONV FOR ALL SELECTED NODES
 01148981  VERSION=WINDOWS x64   21:23:59  MAR 11, 2024 CP=     29.406
 ELEMENT  LKEY     FACE NODES       FILM COEFFICIENT      TBULK
     350     2           1            1000.00000      500.000000
                         3            1000.00000      500.000000
     351     2           3            1000.00000      500.000000
                         4            1000.00000      500.000000
     352     2           4            1000.00000      500.000000
                         5            1000.00000      500.000000
     353     2           5            1000.00000      500.000000
                         6            1000.00000      500.000000
     354     2           6            1000.00000      500.000000
                         7            1000.00000      500.000000
     355     2           7            1000.00000      500.000000
                         8            1000.00000      500.000000
     356     2           8            1000.00000      500.000000
                         9            1000.00000      500.000000
     357     2           9            1000.00000      500.000000
                        10            1000.00000      500.000000
     358     2          10            1000.00000      500.000000
                        11            1000.00000      500.000000
     359     2          11            1000.00000      500.000000
                        12            1000.00000      500.000000
     360     2          12            1000.00000      500.000000
                        13            1000.00000      500.000000
     361     2          13            1000.00000      500.000000
                        14            1000.00000      500.000000
     362     2          14            1000.00000      500.000000
                        15            1000.00000      500.000000
     363     2          15            1000.00000      500.000000
                        16            1000.00000      500.000000
     364     2          16            1000.00000      500.000000
                        17            1000.00000      500.000000
     365     2          17            1000.00000      500.000000
                        18            1000.00000      500.000000
     366     2          18            1000.00000      500.000000
                        19            1000.00000      500.000000
     367     2          19            1000.00000      500.000000
                        20            1000.00000      500.000000
     368     2          20            1000.00000      500.000000
                        21            1000.00000      500.000000
     369     2          21            1000.00000      500.000000
                        22            1000.00000      500.000000
     370     2          22            1000.00000      500.000000
                        23            1000.00000      500.000000
     371     2          23            1000.00000      500.000000
                        24            1000.00000      500.000000
     372     2          24            1000.00000      500.000000
                        25            1000.00000      500.000000
     373     2          25            1000.00000      500.000000
                        26            1000.00000      500.000000
     374     2          26            1000.00000      500.000000
                        27            1000.00000      500.000000
     375     2          27            1000.00000      500.000000
                        28            1000.00000      500.000000
     376     2          28            1000.00000      500.000000
                        29            1000.00000      500.000000
     377     2          29            1000.00000      500.000000
                        30            1000.00000      500.000000
     378     2          30            1000.00000      500.000000
                        31            1000.00000      500.000000
     379     2          31            1000.00000      500.000000
                        32            1000.00000      500.000000
     380     2          32            1000.00000      500.000000
                        33            1000.00000      500.000000
     381     2          33            1000.00000      500.000000
                        34            1000.00000      500.000000
     382     2          34            1000.00000      500.000000
                        35            1000.00000      500.000000
     383     2          35            1000.00000      500.000000
                        36            1000.00000      500.000000
     384     2          36            1000.00000      500.000000
                        37            1000.00000      500.000000
     385     2          37            1000.00000      500.000000
                        38            1000.00000      500.000000
     386     2          38            1000.00000      500.000000
                        39            1000.00000      500.000000
     387     2          39            1000.00000      500.000000
                        40            1000.00000      500.000000
     388     2          40            1000.00000      500.000000
                        41            1000.00000      500.000000
     389     2          41            1000.00000      500.000000
                        42            1000.00000      500.000000
     390     2          42            1000.00000      500.000000
                        43            1000.00000      500.000000
     391     2          43            1000.00000      500.000000
                        44            1000.00000      500.000000
     392     2          44            1000.00000      500.000000
                        45            1000.00000      500.000000
     393     2          45            1000.00000      500.000000
                        46            1000.00000      500.000000
     394     2          46            1000.00000      500.000000
                        47            1000.00000      500.000000
     395     2          47            1000.00000      500.000000
                        48            1000.00000      500.000000
     396     2          48            1000.00000      500.000000
                        49            1000.00000      500.000000
     397     2          49            1000.00000      500.000000
                        50            1000.00000      500.000000
     398     2          50            1000.00000      500.000000
                        51            1000.00000      500.000000
     399     2          51            1000.00000      500.000000
                        52            1000.00000      500.000000
 01148981  VERSION=WINDOWS x64   21:23:59  MAR 11, 2024 CP=     29.641
     400     2          52            1000.00000      500.000000
                        53            1000.00000      500.000000
     401     2          53            1000.00000      500.000000
                        54            1000.00000      500.000000
     402     2          54            1000.00000      500.000000
                        55            1000.00000      500.000000
     403     2          55            1000.00000      500.000000
                        56            1000.00000      500.000000
     404     2          56            1000.00000      500.000000
                        57            1000.00000      500.000000
     405     2          57            1000.00000      500.000000
                        58            1000.00000      500.000000
     406     2          58            1000.00000      500.000000
                        59            1000.00000      500.000000
     407     2          59            1000.00000      500.000000
                        60            1000.00000      500.000000
     408     2          60            1000.00000      500.000000
                        61            1000.00000      500.000000
     409     2          61            1000.00000      500.000000
                        62            1000.00000      500.000000
     410     2          62            1000.00000      500.000000
                        63            1000.00000      500.000000
     411     2          63            1000.00000      500.000000
                        64            1000.00000      500.000000
     412     2          64            1000.00000      500.000000
                        65            1000.00000      500.000000
     413     2          65            1000.00000      500.000000
                        66            1000.00000      500.000000
     414     3          66            1000.00000      500.000000
 Set Encoding of XML File to:ISO-8859-1
 Set Output of XML File to:
     PARM,     ,     ,     ,     ,     ,     ,     ,     ,     ,     ,     ,
 DATABASE WRITTEN ON FILE  parm.xml
 EXIT THE MAPDL POST1 DATABASE PROCESSOR
