Ansys Learning Forum Forums Discuss Simulation General Mechanical MAPDL convection load with variable film coefficient and bulk temperature Reply To: MAPDL convection load with variable film coefficient and bulk temperature
Chandra Sekaran
Hello Francesco, can you go to Post1 (example commands below) and see if the loads are being applied properly?
/post1
set,last   ! last time point
cmsel,s,nozzle_selection    ! select the nodes of the nozzle
nlist             ! list and make sure the X coordinates are in the range of 0.13 to 0.20
sflist         ! based on time and X you should be see if the right values are being applied from the table.
Right now I am not sure whether you are saying the load is not being applied correctly or if you are saying the load is being applied correctly but the results are wrong.
