Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Setting up DCS services for a cluster › Reply To: Setting up DCS services for a cluster
Thanks for the reply. I noticed this as well. Where would I check this setting? I am intending to run on linux, so the windows filepaths are incorrect. In the DC evaluator settings on the head node of the slurm cluster, the machine is set to linux and solves when set to direct. When setting to submit to RSM, however, the submission fails with the error above. When setting to RSM the only other option I see is "queue" where I have typed in the name of one of the RSM queues. I do not see anywhere to specify the platform type, however I would asume this should be taken care of by the RSM head node on the slurm cluster like it is during normal submissions to the RSM head node.
