Ansys Learning Forum Forums Discuss Simulation Photonics Can not launch CML compiler in Linux Reply To: Can not launch CML compiler in Linux
Guilin Sun
You may try to use the terminal to run the “cmlc” command. Note that you will need to setup the path in the bashrc file. This is talked about in this page: https://optics.ansys.com/hc/en-us/articles/360037135654-System-requirements-and-installation
Usually CML works fine for Linux system.
