Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Deflections not matching for simple cantilever beam check › Reply To: Deflections not matching for simple cantilever beam check
Jim Day
Using *ELEMENT_SHELL_COMPOSITE, the through-thickness integration points are located at the center of each of layer.   *ELEMENT_SHELL uses Gaussian integration by default.   Integration point locations for Gaussian integration are tabulated under *SECTION_SHELL in the User's Manual.   I would expect Gaussian integration to be more accurate.   If you increase the number of layers in *ELEMENT_SHELL_COMPOSITE, I would expect the solution to improve.
