Ansys Learning Forum Forums Discuss Simulation Fluids Multiphase model doesn’t give good results Reply To: Multiphase model doesn’t give good results
OK thanks, so the sources are linked solely to the UDS which isn't then attached to any fluid properties: just needed to clarify.
There's no reason that the solver should stick like that, equally, I'd expect it to need more than 10 iterations to correct like it has. Not sure, I'll do more digging.
