Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Deflections not matching for simple cantilever beam check › Reply To: Deflections not matching for simple cantilever beam check
March 11, 2024 at 1:32 pm
Hi Eli,
How can you compare /expect the same results between two element formulations that are different in how the fields are calculated and work?
I mean added integration points and differences in the location of them might cause some differences as you are observing here.
Have a reading from the following slides for further information on elements.
https://www.dynasupport.com/howtos/element/shell-formulations
Cheers, Ram
