Ansys Learning Forum Forums Discuss Simulation Fluids 6dof solver – Inertia tensor Reply To: 6dof solver – Inertia tensor
Federico
What is your time step size? You need to set a time scale that doesn't excessively rotate your object relative to the surrounding within a time step. A good rule of thumb is to start with 0.5-1deg of rotation per time step. Start with this and see if this helps
