Ansys Learning Forum Forums Discuss Simulation 3D Design High temperature gas flow in a furnace at underpressure (p<1 atm) Reply To: High temperature gas flow in a furnace at underpressure (p<1 atm)
Federico
Once your solution is initialized, you then have the option to "Patch", or assign values, to entire cell zones in your domain. In Fluent, you will find the option to Patch in the Solution Initialization task page.
