Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Condensation in Shell and tube heat exchanger › Reply To: Condensation in Shell and tube heat exchanger
If the liquid fraction is too low to show why is the VOF model a good choice?
You currently have two distinct fluid domains, and that can make convergence tricky. If you remove the water domain, but set a boundary condition on the water surfaces to reflect the cooling you simplify the model and reduce the cell count.
