Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Gasket Bulge › Reply To: Gasket Bulge
March 11, 2024 at 1:07 am
Hi Peter,
I have managed to improve the convergence problem by applying the Nonlinear Adaptive Region tool. After doing physical tests in the lab, I measured a 10% increase in thickness around the indentation area when the centre was indented to 50% of the original thickness, but the simulations are showing only about a 1% increase in thickness. Do you have any advice on how to make the simulations yield the same results as the experiments? Thank you again!
