Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › fluid model displacement factor › Reply To: fluid model displacement factor
Maryam Tabbakhh
I still have a problem with applying scale factor to the fluid. we wanted to check if the fluid works properly and needed to exagerate the fluid displacement in the animation. When I apply scale factor to the displacement for the fluid, the whole fluid jumps out but the deformed shape is still the same. The wave height doesn't change. Is there anyway that I can see the amplified motion through the displacement scale factor or anything else? I tried the lsprepost4.11 and still the same problem.
Thank you so much
