Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting .cdat and .cas files using TUI › Reply To: Exporting .cdat and .cas files using TUI
March 8, 2024 at 8:32 pm
Jose Amigo
Hi Rob,
Thanks for the reply.
I tried your command and apparently it does the same as cdat-for-cfd-post-&-ensight. However, I noticed the following: the first time I execute this in the TUI, it writes both .cdat and .cas files, but if I continue doing it will only keep saving .cdat files. It only works 1 time. It will only save the .cas file again if I close and re-open Fluent.
