Ansys Learning Forum Forums Installation and Licensing Ansys Products Ohmic Loss Calculation by Ansys Maxwell Reply To: Ohmic Loss Calculation by Ansys Maxwell
Mohendro Ghosh
Hi HDLI,
Thanks. yes, I am doing the same as you have suggested.
In open circuit, I am using Steinmetz Eq. for magnetizing core loss calculaiton with "Power Ferrite" loss option in ansys.
Can you answer me the below questions:
  1. what do you mean by using rate current? Does it mean, I should use current source both in primary and seconary?
  2. As you noticed, I am assuming "Ohmic Loss" as induced eddy current loss in core due to leakage flux (by field calculator). Am I in right path to calculate this considering Ohmic Loss? Also, I am getting same amount of loss as "Solid Loss". Are these two the same things? please explain me.
Thanks
Mohendro.
