Ansys Learning Forum Forums Discuss Simulation 3D Design High temperature gas flow in a furnace at underpressure (p<1 atm) Reply To: High temperature gas flow in a furnace at underpressure (p<1 atm)
Federico
Hello Yves,
after initializing your solution, you can patch the fluid with the desired pressure (100 mbar). Just setting the outlet pressure will not be sufficient for this.
