Ansys Learning Forum Forums Discuss Simulation General Mechanical Mecanical solver bottleneck/limit Reply To: Mecanical solver bottleneck/limit
Kaushal Vadnere
Is your part symmetric in any direction? If yes, maybe you can use planar symmetry to reduce the model size. For your question regarding mesh size, the ideal mesh size depends on various factors such as the complexity of the geometry, the expected gradient of the field variable, and the computational resources available.
See if this post on forum helps: Element Size : What does that indicate ? (ansys.com)
Thanks!
