Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Aorta CFD › Reply To: Aorta CFD
March 8, 2024 at 3:15 pm
Hello Miguel,
I would suggest using the Fault Tolerant Meshing (FTM) workflow for this. You can import an .stl file directly into Fluent Meshing and use FTM.
Here are a few links to get you started:
New Fluent Meshing Workflow Quickly Wraps Non-Watertight, Dirty Geometries (ansys.com)
ANSYS Fluent: Fault Tolerant Meshing Workflow - Ansys Knowledge
Chapter 6: Exhaust System: Fault-tolerant Meshing (ansys.com)
Chapter 4: Using the Fault-tolerant Meshing Workflow (ansys.com)
