Ansys Learning Forum Forums Discuss Simulation LS Dyna Cannot see material failure in simulation Reply To: Cannot see material failure in simulation
Ram Gopisetti
Hi Joshua,
can you post your material card here ?, Did you define D1-D5 parameters ?, Are there any additional failure criteria defined?
Is the strain rate in your model enough to progress to failure?
Cheers, Ram
