Ansys Learning Forum Forums Discuss Simulation 3D Design Fluid Flow: Conflict between two volumes Reply To: Fluid Flow: Conflict between two volumes
Devendra Badgujar
Hello Philippe,
Is the heat BC set on the surface or on body? Try setting up heat on body instead of the face and check.
Thanks,
DevendraÂ
