Ansys Learning Forum Forums Discuss Simulation 3D Design Coordinate system for beam section properties Reply To: Coordinate system for beam section properties
Devendra Badgujar
In Ansys SpaceClaim, you can define the coordinate system for beam section properties. This is done by selecting a beam in the Beams folder and changing the properties found in the Beam section of the Properties panel. Here, you can select the location where the profile intersects with the path of the beam: Area Centroid, Shear Center, or Location.
If you select Location, then you can enter the X and Y coordinates of the anchor location. Area Centroid is the default
Let me know if this helps.
DevendraÂ
