Ansys Learning Forum Forums Discuss Simulation Electronics Error in 3D magnetic gear simulation Reply To: Error in 3D magnetic gear simulation
abankusomari
Thanks Sir , i took my time to do it and it worked out successfully.I am very grateful.my problem was the results obtained for max torque as compare to 2D simulation was not the same.The results obtain for 3D simulation was quite lower compared to 2D simulation.Can you kindly help me.
