Ansys Learning Forum Forums Discuss Simulation General Mechanical Composite Pressure Vessel Reply To: Composite Pressure Vessel
harshanagasai668
I am currently trying to model a copv with Isotensoid domes. I have successfully analyzed the cylindrical section but the dome portion is a bit challenging. I got the variable thickness with cut off section rule but the change in winding angle is not achieved even thought through look up tables. How did you do it?
