Ansys Learning Forum Forums Discuss Simulation Photonics Exporting a large number of data sets into TXT from varFDTD Reply To: Exporting a large number of data sets into TXT from varFDTD
Guilin Sun
Ex,Ey are complex fields;
what you calculated is the real part. Usually people do not use the real part, since it does not give information of the magnitude. You should save complax number, and use Python or other language to process the data as you wish.
