Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › lS-DYNA Warning messages-Contact › Reply To: lS-DYNA Warning messages-Contact
March 7, 2024 at 9:03 pm
Thanks for your reply.Â
The warnings are:
1: SECTION_SHELL(ID: 1): thickness is less than 0.5. Refby 2 parts: 1 2..... warning(2)
1: ELEMENT_BEAM(ID: 2449): Beam distance is too small..... warning(47177)
For beam-to-beam contact, the contact should be created for each beam part. Say if I have three different beams interact with each other, I will create three contacts, right?Â
Another question: for discrete beams(form 6), what is the best material to be assigned to act as a nonlinear spring with one axial DOF?Â
ThanksÂ
