Ansys Learning Forum Forums Projects & Partners Ansys Innovation Courses Error running Bolted Pressure Vessel model Reply To: Error running Bolted Pressure Vessel model
Daniel Miano
I removed part of the vessel and changed the fixed support to the surface around the green circle in the image below. Now the total nodes + elements = 114,991 and I get the same error.
Then I changed the element size to 0.7mm and now the nodes = 36,635 / elements =  8,162. This model runs, but I had to increase the element size larger than the tutorial instructions (0.5mm)
