Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Autodyn History tab does not change into plot/graph view mode › Reply To: Autodyn History tab does not change into plot/graph view mode
March 7, 2024 at 6:03 pm
In Autodyn GUI, you need to check the right-most button. If it is checked as shown in the picture below, it means that the interruption of plotting is activated. Then no matter what button in Autodyn GUI is clicked, there will be no change in Autodyn View Panel, just like what you have observed.
If you want to continue the plotting process, you need to click this button to change it to cross. See the picture below. Alternatively, you can exit and restart Autodyn to restore its default settings.
