Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Shear Test – Mooney Rivlin › Reply To: Shear Test – Mooney Rivlin
Akshay Maniyar
Hi Hary,
As per the error message, it looks like you have some issues with the material you are using. The elastomer sample material that you have used has only test data which is needed to create the hyperelastic material model. Go to Engineering data and create the proper material model. Please ensure that you have all the material properties defined as per the analysis you are performing.
How to Perform Curve-fitting for Hyperelastic Material Models — Lesson 1 - ANSYS Innovation Courses
Thanks,
Akshay Maniyar
