Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › FMU using Motor CAD › Reply To: FMU using Motor CAD
Thanks for the reply HLDI
I ran stand alone simulation but the temperature values are really high the maximum values are reaching 1x10e7 °C in transcient simulation (in Matlab using FMU).The actual max temperature is around 150°C in Motor CAD.
is it possible to run only duty cycle simulation in FMU but not the transcient simulation?
Also I have listed down the results which I got from your suggestion
Suggestion 1:- I had ran only thermal model the simulation is running but the model is running infinitely.
Suggestion 2:- The step size used is auto,not zero step size used.
Suggestion 3:- I had already did this in the previous comment and this was the result
Regards
Ganesh
